Gelöst Bios is updating LED firmware
Nexociety
Hi, seit einigen Tagen bekomme ich bei jedem Neustart, noch bevor ich überhaupt die Möglichkeit habe ins Bios zu kommen, die Meldung "Bios is updating LED firmware". Die bleibt dann ca. 40 Minuten bis der PC normal hochfährt. Ich habe schon in allen möglichen Foren nachgeschaut und Ideen von dort ausprobiert, aber bis jetzt hat nichts geholfen. Der Asus Support wusste auch keine Lösung.
Mainboard: Asus ROG Strix B450-F Gaming
Ich hoffe ihr könnt mir helfen.
Stein
1.715
1.327
Das ist die Lösung eines anderen. Kurz übersetzt: versuch Asus Aura im bios zu deaktivieren.
Fellows, I had the same problem, but finally was solved.
When I first assembled the mobo and installed the windows 10, I had no problems at all
Then, I installed Asus Grid with a lot drivers and some tools. At this moment, my problem started. 45 min to boot, with same message.
I tried update BIOS, nothing
tried disable Aura on windows software, nothing
tried update other drivers, nothing
looked for more information on internet, almost nothing
well, at that time I thought to rewirte the bios using the DVD that comes, using procedure to recover corrupted BIOS.
I Turned off and connected the DVD drive.I entered on bios setup, and before try the DVD I tried also update BIOS from Internet direclty from BIOS setup, which booted the mobo and gave me the answer that firmware was already updated. After that, on Windows, I installed AI Suite 3 and EZupdate, tried disable Aura. Boot again, entering on bios setup again.
Well, I tried to disable the aura (on bios) and changed value to enable virtualization. Booted, and then no more problem.
I am not sure if was disabling aura on bios, or a combination of changes, or a sequence, but it is working for me right now. I will not try to enable aura again until be sure what is the problem.
Just forgot to say. Mine is a B450-i, 32GB RAM Corsair Vengeance 2666, NVM Samsung EVO 970
Hier der Thread dazu.
